Discuss Optima alarm system problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you tried removing the mains power and battery power?
This can sometimes reset faults. It may reset the codes back to factory settings so make sure you know them .
Thanks, I haven’t tried anything yet so will give it a go. I’ll figure out he factory settings first, thanks for the warning.
Brilliant, thanks. Fingers crossed but I’ll call if I have any trouble.that is an old system . looks like had new battery 2012. power up, 0123 is the factory code. it may have reverted to this.Warrington is on my patch so if in trruble, i can fix,
Reply to Optima alarm system problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
