J.C.E
Afternoon
Looked at a rewire/ rear extension job today
They are turning the one property into 2- the ground floor side annex will consist of 1x dining/kitchen area and bedroom with en-suite (gas heated)
So electrical load will not be a issue
They do not want a new head and meter for the 2nd property becuase of the ££ of that
is there anything wrong with this:
head>> meter company meter>> henley block
henley>> DB1 of main house
henley also>> 100a check meter (consumers owns this meter now?)
100a check meter>> switched fuse isolator
switch fuse isolator>> DB.2 in side annex via a swa
100A Single Phase Digital Check Meter | ElectricalDirect - https://www.electricaldirect.co.uk/product/100a-single-phase-digital-check-meter-436268
or is there a better option?
I have seen a few properties in Bath with one cutout and 2 meters, one meter per flat.
Often see it in the large townhouses over 5 stories with a 3 phase cutout . basement and ground on one phase. first and second floors on phase 2, then 3rd and 4th floor on phase 3. each floor being an apartment with its own meter down by cutout and then swa going upto the consumer unit in the flat.
In the OP, the configuration means the main house will be billed for both the house and the annex as one property. The homeowner will then have to charge the family member using the annex through the check meter readings.
This check meter will not be calibrated as the DNO one is.
Call it what it is.... it’s a granny flat.
You can get sub meters that take a paper card.
The tennant purchases from the Landlord £10 or £20 cards and just inserts them into the meter as and when.
The landlord gets the bill for the main meter
J.C.E
Earth
1 head, 2x properties- check meter
J.C.E,
solarsavings,
