Discuss 12v ac relay not pulling in in the UK Electrical Forum area at ElectriciansForums.net
hoover
Hi I've installed a 12v ac relay but the 12v supply won't pull the relay coil in. It gets it signal from a disabled alarm kit. Multimeter shows a healthy 12v when alarm is activated but relay won't energise. Tried a couple of different relays but no joy. ????
check that the relay is a 12v coil.
You dont indicate what you are switching with the relay ? remember the alarm 12vac wil be jus enough to switch the electronics
More information is required
Make sure the coil is not too big for the supply it could be you have the right coil but the supply 12v may not be big enough
You'd get some clue by looking at the voltage across the coil when its energised. If it's significantly lower than 12V, say less than 10V, then you may need a relay with a higher coil resistance. The relay spec sheet should say what the minimum voltage for pull-in is.
Reply to 12v ac relay not pulling in in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m stumped and can usually figure it out after a while but not on this one. so I joined here In search of some help on my 05 tundra I’m...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Hi I am reconfiguring a hot wash unit and need to use a flow switch as in attached files. It controls a light powered relay and timer module I...
