Hi I recently ripped out a ring final circuit out of an old Proteus 3ph board. Customer only wanted a single 2G socket replaced. The MCBs are obsolete so I had to re use the C32 used originally supplied the ring.
can I use 2.5mm cable?
32A radial but with 2.5mm cable- not something you would see in appendix 15, but then thats only a guide and I ve only got one socket on the end, so does 433.3.1 ii apply?
Also no different to spurring off a ring?
This is just for discussion's sake as I ended up putting 4mm in, incase it was added too at a later date.
just interested to see what other thought?
