Discuss 2 way 2 gang light switch problems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
EGerrard
Hi,
I bought new chrome light switches to replace the plastic ones - one upstairs 2 gang and one downstairs 1 gang. The switches control the hall light, and the upstairs one also does the bathroom light. At the moment they aren't linked i.e you can't turn the hall light off upstairs if you turned it on downstairs. I just assumed the house wasn't wired properly. But putting the new switches on I realised there was a two loose wires and in actual it wasn't wired properly. I have now wired them as per 2 way and they are now linked and work. My problem is now the bathroom light no longer switches on. I thought on a 2 gang switch the two switches are independent of each other so why isn't it working? Is this the reason the switches, upstairs and downstairs were not linked in a 2 way? The bathroom light seems to only have one wire which is strange but it seem to work fine before. Any help or advice you have give would be much appreciated. I took a photo of the wiring before I took of the plastic switch you can see only one wire going into the COM and the loose wire and how I have wired it now. (not sure if they have uploaded I am struggling to do it)
If that's T+E and the 2 black wires that are missing in that picture are neutrals connected together in a block, then the red going to the bathroom is a switch wire + u need to loop a feed from the adjacent switch. Odd to see a 2 way wired without 3 core though, I presume there are 2 cables at the 1 gang switch!
No, cpc is always cpc, twin brown between switches, single brown from there to landing light, blue and earth from the landing light to the downstairs hall light, bottom of the stairs switch will be fed by a twin brown(hall individually switched) or a brown and earth(hall 2 way switched) from the hall light.
Just to let you know the chrome switch is earthed, the electrics were off and I took that off just for the purposes of the pictures so you could see the other wires better.
I appreciate its hard to tell for the picture, the hall light and upstairs and downstairs light working fine. Just the bathroom switch. Thanks for the advice.
I've seen 1960's houses in the south east wired like that, but frequently the landing light uses the live from the downstairs lighting circuit and the neutral from upstairs; the borrowed neutral causes problems when installing dual RCD boards!
Yip that's why I like joint boxes for lighting, everything back to a central point + able to operate any light from any switch with a single cable, not the most cost efficient as more cable is required but defo makes life much simpler. :)
Same here, borrowing the neutral off the upstairs circuits, its common in pre mid 80's houses here, I warn people at board changes that if it's in their house that it's extra to correct. Last one was a gift thankfully, they were getting new heating system and immersion moved to garage, so plumber had traps lifted everywhere, even right over the pipe for the downstairs switch and the wall behind the landing switch was the old hot press in the bathroom and was open to be ply lined for tiling for a shower lol a tasty bonus since I'd priced it to correct, if there, beforehand. Lol
Thats sounds waaaay too confusing. Loop in to switch. T+Cpc to light. 3 core between switches. Simples :)
Still an apprentice. Be nice haha
I may be sceptical but did you do the screw back in on the earth terminal after you disconnected it?
Just what I'm used to now, Pull your twin brown in and when passing the hall light pull a blue and earth in beside it, and leave the twin brown at the landing switch and take a single brown to the landing light with the brown and earth. Simples lol
Reply to 2 way 2 gang light switch problems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
