Discuss 2nd ask Job sheet template in the Business Related area at ElectriciansForums.net
M
mayfair
Hi guys
Giving it another go! anyone have a good template for a job sheet sort a thing you can fill in when quoting , materials needed/to order etc
Cheers
Ours are printed on a pre historic printer I'll scan one in if you want. I think the office use PDF version which might be prettier if I can get hold of one
Hi guys
Cheers
Hi I just came across this post and I know it is quite old but other people might benefit from this program I've found called BusinessFlow Job Sheet Pro it's a basic job sheet program, keeps your customer details and all the site addresses for that customer, templates can be altered to suit your business and created in pdf. You can have multiple different templates for different parts of your business. It suits our small electrical business down to the ground.
Hope this helps.
- - - Updated - - -
Hi guys
Cheers
Hope this helps.
Reply to 2nd ask Job sheet template in the Business Related area at ElectriciansForums.net
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
