Discuss 3-way siwtch not working in the Australia area at ElectriciansForums.net
I
Ivancar1
HI, i have just moved into my new home and there is 2 switches that are not installed and i have tried to install them, but when i installed them switch A would be on and then Switch be wouldnt turn off the light.
right now both switches are off and the hots are merreted (1 black) (1red)
both switch boxes there is 1 red 1black and 1 neutral
Eh ? Ur not a sparky are you ? If in doubt call a proffesional and let them sort it out
That skint you just bought a new house ? It will take an electrician no time to remedy this problem so wont be that expensive .
yup i bought a new house before i lost my job. and nvm i'll just move on since i have a feeling no ones going to help me here
thanks anyways
Reply to 3-way siwtch not working in the Australia area at ElectriciansForums.net
Hi, I have two 3-way toggle switches by the opposite sides in my garage. Is it possible to replace both of them with motion sensors? Thank you. .grig
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
