Discuss 4 Core SWA - 2 Cores RCD protected, the other 2 not ... in the Australia area at ElectriciansForums.net
U
Unswitched
Hi guys
SWA feeding outside lighting and socket outlets etc.
Set up like this:
Single phase.
L & N T&E out of MCB in main board to feed sperate enclosure with only an RCD module in. So L&N feeding an RCD.
Then, 4 core SWA is glanded to this board.
2 of the cores (L/N) connect to the Mains in side of the RCD (with the t&e)
The other 2 cores are on the load side of the RCD.
So, effectively 2 sets of L/N are taken to a junction box outside somewhere, where I assume one set that is unprotected go to outside lights and the RCD protected L/N pair are taken to socket outlets?
All of this controlled by 1 MCB
Is this correct, I can't really see why not?
What are the cable sizes of the T&E and SWA?
I thought fixed lighting outside and out of reach did not have to be rcd protected (stand to be corrected on this mind :eek:)
Reply to 4 Core SWA - 2 Cores RCD protected, the other 2 not ... in the Australia area at ElectriciansForums.net
Question is does this DB really need RCD protection as there are only internal lights and sockets supplying this large building that used to be a...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
