If you were wiring 8 gangs of 2 way light switches. Would you wire 8 independent circuits, so 8 no. 3 core between switches. Or would you run a live, and loop all the L1's together, then just run 8 no. 2 core between switches ?
I would love to see a pic of the 8 gang after it's been labelled up because I'm tying to picture it in my mind as to how aesthetically pleasing it's going to look in a domestic environment.
Unless hidden under the stairs, I can't see any nice way to label this in a domestic environment. It's likely that whoever wants a bank of 8 switches will memorise each one, while everyone else in the hose will try them all and leave lights on everywhere.
I engrave stuff a lot, this is in my hallway. To make this more discreet I could have filled it with white wax, the white wax colour is different enough that you can read it up close but from across the room it looks unmarked.
That looks good, I spoke with Hager to see if they did custom labels, but unfortunately not. They recommended some key cutters do engraving. I'm gonna try that. Where did you get your engraver, how much did it cost, can you do switches instead ?
When I was an apprentice, I had to engrave a lot of white plates for EM test switches etc
Can’t even remember how it was done, but it would be described as “manual”
A clamp, a stencil and a steady hand.
Years later when I was at uni, I took a job at an electricians in their stores. They had a computer controlled version of the same machine.
The engraving machine is just a cheapsih 3040 type Chinese CNC mill similar to this one. The largest cost is the licences for the CAD software and the MACH software to run the machine.
I've never tried to engrave the switch rockers themselves I might give it a go. Most manufacturers screen print the markings for their switches. Years ago we had Crabtree mark a load of switches for use in a housing development. I've no idea what the cost or minimum order was though.
As an Amazon Associate we earn from qualifying purchases.
Seen plenty mistakes when other apprentices tried engraving… Tumble dryer/drier or just having “FF” for fridge freezer.
The engraved letters on white plastic was rubbed over with coloured wax…. (A professional crayon) and the coloured bit stayed inside the cut away part.
We also made plastic signs that were made up of plates of laminated coloured plastic. So the engraved part would cut through the top layer revealing whatever the second layer colour was.
Traffolyte.
Is that Mach3 / 4 by Artsoft?
What CAD software do you use?
Mach 3. I use Vectric Cut 2D Desktop for making up signs and plates as it will engrave simple text to traffolyte and cut out fixing holes and panel button holes and the plate itself. And Stickfont V2.6 for engraving text on switches and things as it is substantially more flexible for text. Was making these ready for this week splitting offices to 3 separate suppliers meters.
Makes my Dymo look very inadequate
It even make my Brother PT550 look a bit sad, but I am happy with it, better than a Sharpie by a long way, reminds me must make a sticker to go over the Wylex Logo. 🤣DSC01993.jpeg
It even make my Brother PT550 look a bit sad, but I am happy with it, better than a Sharpie by a long way, reminds me must make a sticker to go over the Wylex Logo. 🤣View attachment 98840
Cricked my neck now.
Ps what's a devise ?
Instalation ?
Doesn't instil much confidence have you printed a lot of those labels ?
Something that's intriguing me
Kitchen socket sink side 32 amp
Kitchen socket hob side 32 amp
3 ring finals ?
4mm radials ?
pt550 doesn't like printing "sockets"
If you had one of those in the 90s you would be the bees knees :)
Kent
8 gangs of 2 way light switches - wiring
Michaelwgroves,
mainline,
