It is on a 30A rewirable fuse, old wylex type. wasnt taking the fuse out tho.
got the job of sorting it all out tho, one of those jobs that your not sure you want to do or not....
Well, of course no one will use the full power unless there is a serious desire of self boiling. However, 2.5mm for a 9500W shower is definitely a silly think to do.
I would consider a 6.0mm cable (9.5X4.2=39.9Amps)
Anyway, 2.5mm cable did survive for a number of years! How about a 6.0mm cable then? Remember guys, cable does not burn in the middle; it is either the beginning or the end! Always check your connection!
ive been "playing with wires"as wife calls it for 20 years and ive just finished a job i should have checked out a bit more before qouting!!! if its anything like one ive done itll be added and added,from now on im going to be more thorough espically if you likley to be changing c/u,an extra half hour inspecting etc should give you better idea of what you have to do,allow you to quote more accuratley,ie hours to do work and hopfully save you coming across somthing nasty and if youve quoted a fixed price extra labour etc eating into your profit................as it did with me.......ehem! always learning,somtimes earning.....
Ross Trician,
CUDABOY,
