Discuss Adding a PIR outside light to existing lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all,
I have been asked to install a PIR outside light on a commercial property. The feed has to come from the existing lighting circuit inside the stockroom which is on a two way switch system. I need the PIR light to work independently from the switched inside lights. The outside light come prewired with regular twin and earth. Please advise on the best course of action. What is the best way to wire this?
is it a led Pir security light. then the fly leads need to be put in a ip rated box from their weather you drill through a wall it is up to you
by taking a feed to switch & from their to the new led pir light
No offence to the OP but this is a straightforward issue. the fact the lighting circuit has 2 way switching is neither here nor there.
Find the feed, junction it taking a feed to the new light and incorporate a switch if required on the live. not rocket science and quite a straightforward job.
meant to add, despite having a pir on the new light fitting, quite a few of them have this function built in that flicking the switch rapidly once or twice will put it into constantly on mode (manual)or back to auto and utilising the PIR. each model has its own quirks and functions mind. also the switch whilst not absolutely required also allows a means of isolation if done properly.
Reply to Adding a PIR outside light to existing lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
