Good evening,
I’m looking for some advice from experienced electricians please.
Currently having some work carried out by a new sparky due to mine being on holiday. The work he is doing is to an ok standard, but the only thing which has caught my attention in he has placed all the lights, 9 in total on one circuit (16a). Is this ok? Best practice? Meet regs?
Thanks in advance
Good evening,
Thanks in advance
All the lights in the house on one circuit, or one floor? What sort of house is it?
Doesn't sound good at all...
The idea is that each floor has its own circuit, so if,say the downstairs goes off, theres "borrowed" light from upstairs to see your way about.
Also, placing all the lights on a 16A? You sure that's not 6A?
I ask because regular domestic light switches are only rated for 10A.
Unlikely scenario, but if there is a fault, your switch will break before the breaker does.
Is there a reason to put it all on one circuit? Number of ways in the board etc?
Sounds like this electrician is straight out of a Western. Check he doesn't turn up on a horse with a ten gallon hat and a six shooter (does he say "yeeha" a lot?)
Oh, I see hes already done some work. Can we see any photographs of the CU as an example?
No mate, but I’ve paid him 1k for new consumer unit, lift the sockets up from skirting and everything to co inside with regs
[automerge]1583174607[/automerge]
That’s what I thought. Thanks for your input bud, appreciated
Ah ok, I'd assumed a full rewire, sorry.
When changing a consumer unit you can only really work with what's there. It may be one existing circuit, but by the sounds of it the circuits were separate before the work commenced ?
In which case it might be that the circuits have common conductors, shared neutrals, which prevent them being put on separate RCD devices.
Rewiring the circuits to suit at extra cost to yourself would be the only way to solve this.
This should have all been explained to you though really.
16A device sounds odd.
So no work to the lighting then? So why do you say he put them all on to one circuit if he hasn't done any work on the lighting?
I assume he means no obvious visual work has been done. He'll hardly know if the sparky has wired 2 circuits into 1 MCB.
Have to confess I have merged all the lights on one circuit when there has been a borrowed neutral between the floors, usually on the stairs/landing. actually discussed this on an assessment visit as I had upgraded the rewireable board to incorporate RCD protection and mcbs but customer did not want the wall chased to sort the lighting.
not best practice but it was still an improvement on what was there. assessor took view thatwhen upgrading it is not always possible to bring it to the current standard like a new install but record it on the test cert anyway as deviation
Uk
United Kingdom
Other
If other, please explain
Investors
Business Name
BDS Investments
All lights in residential on one circuit?
UK
Jasebds,
westward10,
