Discuss Cable to outbuilding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Macca . the outbuilding is remote from the existing main building.....be it 1m. or 100m. therfore if it is to utilize the existing fault protection of EEBAD [ADS],then the equipotential zone extends to the outbuilding which means 10mm2 bonds to any extraneous conductive parts whithin it. Alternatively the outbuilding can form its own equipotential zone by creating aTT system.............if no extraneous conductive parts then no problem !
spark1
So what you're saying is,if you had a shed in your back garden with an existing supply already feeding a socket,you would still spike the shed.:confused:
If there where extraneous conductive parts insidethe shed and the supply cable was less than 10mm ,on a tncs supply,then i would probably run in a 10mm2 seperate bonding conductor from the M.E.T in the house....if this was not easily done then yes i would TT the shed........if no extraneous conductive parts then the problem does not exist.....The o.p doesnt say either way on this issue
Ok mate i give up.You win.Goodnight.Just about to watch Rollerball on Ch5
It wasnt a competition Macca..just trying to help the o.p.
..your team qualified for next seasons Champions league eh ! Congrats....Liverpool fan myself....will see you there
Goodnight !
spark1
Reply to Cable to outbuilding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. I've recently bought a bungalow. It currently has a armoured cable between the house and garage which spans less than 1 meter. The height...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
