V
vwes59
...and why would I want to do that ?
Well, I'm faced with a real botch job of a consumer unit. Essentially this is a "new" consumer unit only put in a couple of years ago by a friend of the clients family who was apparently an electrician. However the unit they bought (a Niglon) had the main switch on the left side, the tails were only long enough to reach the right side (Don't ask why it wasn't positioned correctly, I've no idea). So they "adapted" the unit so the main switch is now on the right side, but has a second main switch in the middle made by Eaton! which I'm assuming they thought would act as an RCD, which of course it doesn't. It's a mess inside to be honest, and I'd love to rip the thing out and start again, but I can't because its been built into the wall, and the client doesn't want to mess up the extension which has just been redecorated. It has so many things wrong with it, I've had to hand a dangerous condition notice to the client and refuse to do any work unless its put right (That's to protect me and them).
Anyway they've come back and asked me to put it right. To put it back the way it should be and get rid of the bits that shouldn't be there, the tails are not long enough, so I wondered can you extend the tails inside a consumer unit, if so what's the correct way to do it ? The 3M length would not be exceeded as the the meter is the other side of the wall, so I doubt they exceed 2M let alone 3M. As I said, I can't move the thing or probably find one that's exactly the right size for the hole in the wall, so I'm stuck with what I've got.
