Discuss Coaxial sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
Sparky_Ben
what is the dirrerence between screened and un screened coaxial wall sockets, for what I can see is price is the only difference?
thanks in advance
If its being fixed miles from any other cabling or sockets use the cheaper unscreened ones. If you are within a foot or so of anything use the dear ones. I f you don't you will be possibly troubled by interference as load changes within the cables generate electromagnetic fluctiation, Hall effect, induction, magnetism and heating of cables. (I assume its for a TV, so this will give you "snow" or crackles)
Tightwad anyway....theres only pennies difference :)
screened cable are you meaning wont need a screened socket? I dont know what type of cable it is if this is what you mean I am just goin to put a socket plate on to neaten it up
if the coax has a metal foil inside then its screened.
However, that does not mean its not run alongside mains cables somewhere.
For your own piece of mind, if you are unsure then use a screened plate.
Job Done.
Job Done.
YOu should always use Foam filles scfreened Copper over copper Coax cable in all instances. Isolating plates cause more issues than good in most situations coax (aerial/Sat/FM etc) Cat5 (data) and video cables should be run to standards just like T+E. Its crazy ion this day and age that people still think an aerial point is appropriate. Either dont bother or do it properly.
Reply to Coaxial sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I have a coaxial wall plate that is hanging off the wall and needs replacing. How do I wire the old plate which has an IN and OUT for the...
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Apparently Dimplex only guarantee their heaters if they are permanently wired in to a fused outlet. If the socket is only about 600mm from the...
