Discuss Connection above or below terminal screw plate in the UK Electrical Forum area at ElectriciansForums.net
KitKat it goes under and get it real tightDoes a wire attaching to a screw terminal on a standard receptacle outlet go over or under the little brass movable plate, please? Thanks
No the old style has only one way to terminate and that was wrap the wire around the screwGood to know. Is there a technical name for the movable washer type plate under the terminal screw? Have they always been part of electric receptacles? Thanks, kit
Reply to Connection above or below terminal screw plate in the UK Electrical Forum area at ElectriciansForums.net
