Discuss Connector Blocks in conduit boxes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
well an uninsulated standard connector block can surely be seen as a live part plus the fact they are NOT maintenance free?
The standard connector block (chock block) has moulded insulation and all conduit boxes should be earthed (metal) or be insulated (PVC), have screw down lids and be accessible for maintenance. No problem. The twist on porcelain type are non-compliant AFAIK
Reply to Connector Blocks in conduit boxes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
There is a significant price difference between the standard grey wago topjob DIN connector blocks and the blue and green. Is there any reg...
Looking for some advice and timescale here. I'm not an electrician just a tennet with a housing association. I've been offered top floor flat in a...
