- Reaction score
- 10,368
I had a job last week that needed a data logger on a sewerage pump station to monitor the running times during bad rainfall. I have a Hioki PQA / Data logger that cost an arm and a leg which I didn't fancy leaving for several days on site so I purchased a cheapie single channel current/voltage logger rather than chance my expensive one which was overkill for this application and it was also a bit on the large side to fit it into the control cabinet.
There wasn't too much choice available off the shelf where I live so I went with a ST-175 CV1 Data Logger, I think it's manufactured by CEM who are otherwise known as Shenzhen Everbest Machinery Industry Co. As you may have picked up if you're reading between the lines they're a Chinese manufacturing company and the particular item I purchased had no branding on it whatsoever apart from the model number. The price was ZAR 2250.00 which is equivalent to 120 UK quid and I don't mind admitting at this stage I was a bit nervous but it was supplied by a reputable wholesaler so at least there was a possibility of a refund if not satisfied.
What I got was a full kit with everything you need included, current clamp, voltage leads and clips, 2-pin power supply, USB cable, software disk, operators manual and even the AAA batteries. The case is pretty sturdy and in general the build and finish quality of the tester and the other components was good and solid.
One big bonus was the learning curve to use it was very quick, it took 10 minutes to install the software and driver on my laptop (WinXP) and everything just worked without incident. I set the logging parameters which is literally five selections when plugged into a laptop and I had a dry run in the workshop before I took it to site.
On site it took about five minutes to install the current clamp and the logger itself has a magnetic mount or hanger eye option on the back so it's easy to situate it.
The only thing I didn't like about it is to start the logging you need to hold the 'On' button in for 5 seconds until it shows 'Rec' on the screen (Record) but then you still need to press the Start button to start the actual recording process, I found this a bit unintuitive and clunky until I got a bit more familiar with it.
The logger was on-site for just over 100 hours (4.5 days) and because the pumps run for a minimum of 1 minute each time I logged run current at 5 second intervals to establish a load profile. It ran on the no-name batteries that it came with for the entire time and it used less than 50% of its memory capacity so I was very happy with its performance.
The control cabinet it was in was dripping in condensation all over the inside and whilst I put the logger in a fairly sheltered area of the cabinet it was very high humidity. Daytime temperatures reached the mid 30's and nighttime temps were as low as 12 degrees, there were also 2 large storms during the logging period and the unventilated cabinet was outside in direct sun and rain so conditions were pretty harsh. This seemed to have no adverse effects on its operation thankfully.
