Discuss Dimming LEDs in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Large bathroom would be my guess, I have 7 in mine but the ceiling is 2.4mts from the floor.You will kill the fan if you add a dimmer to the circuit...
EDIT: why so many?
To answer your question, yes you can get a dimmer pull switch. You may well have to have the fan on a motion sensor or separate switch. I can do that for you Sir. Anything you want in fact (electrical installation wise I mean. See how I keep the customer happy and get more work? You may find it difficult to get one for LED but I can get around that by locating your switch just outside the bathroom Sir.
Yes true, you will be subbing for me on that one. Skys the limit! bottle of pop packet of crisps as extras for quick work. Sunday 10. a.m. sharp!Mildly creepy that Vortigern but it may just work
If the fan has a run-on timer and the connection between the lights and the fan is just the trigger input for the timer, it may be OK.Damn it, thought the fan would cause a problem!
Was in CEF branch this morning, and they have one set up as a demo on the table. I almost blinded myself.
Hi
I have 6 LED downloghters in my bathrrom. Their the Solo 10. Dimmable apparently. Their 10w each. Is there a way to dim them? Does a dimmable pull cord switch exist?
The fan is also connected to the lights of this makes a difference.
Reply to Dimming LEDs in bathroom in the UK Electrical Forum area at ElectriciansForums.net
