Hey fella's, I was called to a property this week to replace the CU and issue certification for the job. The home owner had only just purchased the place so I asked if he had the condition report, to which he did.
After examining the report, starting my schedule of inspections and throughout the testing procedure I noted the following issues -
No supplementary bonding present including boiler
No gas bonding
No presence of RCD (Old fuse wired style wooden 1960's equipment)
Burnt out dimmer switch in kitchen
single insulation supplying gu10 lamps in kitchen with open strip connector block touching onto downlight trim
Insulation resistance tests failed on downstairs sockets even though last spark issued +299
Insulation resistance failed on downstairs lighting circuit even though he issued a pass
2g Sockets in bathroom
Wrong size cable conductors in various circuits
r1 r2 readings massively varied from his results on days prior
He made no comments regarding no presence of rcd and issued a satisfactory / pass on the cert
Exposed copper and unsheathed earth conductors in a sockets
The above is the basic gist of it however their was more. Obviously I did not issue a cert and wrote out a notification of a potentially dangerous electrical installation.
Can anyone advise on where to go from here, obviously I want to rectify the existing work and issue my cert so we can close the job off but the customer wants to take it up with his solicitor as the condition report was incorrect.
Should I let my scheme provider know in advance and seek advice from them?
Btw, merry Christmas to all on here
Cheers
:drunk:
No gas bonding
Cheers
:drunk:
