Darkwood
In local tesco....Top class work not.....unsupported conduit for several feet vertically socket at bottom leant against fixture at floor level. Twin and earth cable aligned by being hung over a piece of conduit jammed into the tray at ceiling height uploadfromtaptalk1436496386368.jpguploadfromtaptalk1436496408646.jpg
Nice work by a DIY used to supply split bedroom no independent switch and to top it off
Installed in a plastboard wall tenant said she did wonder why the board was burning. .
Parked up in North London and noticed the single blue tied with the bundle of T&E feeding the aircon units lol.
Couldn't find the cutout fuse..SWA feeding the meter with clamp around the armour.
Bonding Crimp.jpgMouse.jpg Found this today, bunch of 10mm singles "crimped" using copper pipe. Second image is of a mouse I found when doing a consumer unit change earlier this year. Just a reminder to you all that lives can be saved by simply sleeving the full length of the cpc and not having excessive copper showing at terminations :juggle2:
Flipping wet pants strikes again
Expansion vessel being held up by a single inch long plasterboard screw. ...service "engineer pushed a screw into the plasterboard to make it look like 2 screws were there,did he not think I'd notice? . ...bodge bodge bodge
It looks awful
But, if you are wiring the replacement boiler, and need to get a cable from the switchfuse and the programmer to the boiler how else would you do it?
I'm speaking as someone who has had to do similar due to lack of available time/spare tiles/budget
I think you'll find that flue is non compliant then!
Presumably it was moved so that it can be fitted into a cupboard, but the plumber couldn't be bothered to drill a new hole got the flue so used the old one!
8K
Darkwood,
mainline,
