- Oct 17, 2011
- 5,313
- 4,858
- 144,758
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- France
- What type of forum member are you?
- Other
- If other, please explain
- Retired Engineer
Yeah they are. When I saw it I thought they were starbreaker. But you are indeed correct it’s a loadstar.Aren't those Loadstar MCBs, rather than Starbreaker? Was trying to picture what might have been rigged up to a plug in busbar.
What was the problem - busbar behind the clamp?Yeah they are. When I saw it I thought they were starbreaker. But you are indeed correct it’s a loadstar.
Loose connection which was also misaligned. Just hadn’t been tightened up properly. So for the sake of saving circa £10 over a loadstar RCBO. They forced a Fusebox one in and will cost circa £600 once it’s all replaced.What was the problem - busbar behind the clamp?
What are those two B6 things on the left hand side.![]()
Looks like Mike was referring to an image on #5714, but quoted your message by mistake.
Did you get the ‘but it’s been fine for years mate’ like I did in the last pub kitchen I worked in.And here we bl**dy go…..
Gone to look at a little commercial kitchen job in the back of a pub….. there’s those alarm bells ringing!
PAT all the second hand equipment the chef has bought in… Tidy up a few bits and pieces….(broken sockets etc) Wire in a gas interlink cutoff when he can get a gas engineer to come.
Not an RCD in the place.
This is the board everything will be coming off for the kitchen.
And these are a couple of issues I saw just walking through the place….
View attachment 97255View attachment 97256
I also saw at least one light switch hanging off the wall behind the bar.
Domestic Aico smoke detectors in lieu of a proper fire alarm system with at least 2 detectors missing and one broken.
Place is a death trap.
A lot of hipster small craft brewery types... No big names.But what's the Beer like?![]()
Feeding 3x radial socket circuits.What's the story with the 3 13A plugs?
What does the MICC from the cutout feed?
^^^^ and where is the earth to the pyro?
Some cunning plan though for the use of the triple gang 13A socket outlet?Feeding 3x radial socket circuits.
Some DIY bodge.
