mine isn't and it's 14 years old. never skipped a beat.
But in your case MFT is Multiple Fluid Tester and it's calibrated for Old Peculiar ?
My own dodgy pic…
Only socket circuit is dismantled to find faulting section. CU other end of house a long way away. All 18v batteries flat. Needed a multi-tool.
Had a mains multi-tool with me. No extension lead.
Options were rigging up builders board and running 16A cables….or…..misusing some kit…
(The DIY adapter dates back several years to a Robin plug in RCD tester and wanting to use probes to test an RCBO)
My own dodgy pic. Been testing an empty school with a non time delayed 100ma main switch rcd on TT. It was being a right royal pain in the --- so I took it out of the equation, safe me thinks so.View attachment 100878
OK I will bite, what are the Green/Yellows by passing the RCD for.
To stop nuisance tripping whilst testing. It is not time delayed and it kept tripping before the rcbos plus it made testing of the non rcbo circuits easier.
A few pictures from today’s encounters
A garden install of consumer unit and double socket🤣(it’s been tripping out the house, wonder why)
and another cable repair job
Looks like an old builders site temp ?
Really odd set up the cabling went from the consumer unit over the fence and into the garage behind supplying lighting and another double socket in 1mm t&e which the owner has been plugging a 13A EV car charging lead into 🙄
Reactions: ipf and Dartlec
I bet it's an old guy who did that.
  • Agree
Reactions: Dustydazzler
This is a strange one, seeing as it's been in and operating for years.
Found it today, in operation, of course.
The face fixings screws where probably tightened with a torque screwdriver.
  • Funny
Reactions: pc1966 and DPG
We need a torque in cheek Emoji.🥴
  • Funny
Reactions: Jim_e_Jib and DPG
Reactions: nicebutdim
There's a gas pipe going into that socket!
People have some weird ideas. Not much work on so give the lads paint and brushes to make things look a bit tidier and that's the result....It doesn't cover up the sh8te standard of work of the additions and alterations, though. It's a few years back now but some RCD sockets had to be changed after being painted over.
I do some work at a couple sport centres and when it has been quiet instead of the staff sitting around picking their ears they have been painting all the door frames , conduits , surface trunkings and ever light switches and sockets BLUE to match the walls 🙃
So they have a job changing the RCD socket, eh? Swap it, fix it back....oh, the lugs have snapped.....let's just leave it????
It's happened whilst in use, somehow.
Reactions: pc1966
8K
Darkwood,
mainline,
