Hi All,
Just a quick question, I need to get my gas & cooker installers to check earth and bonding conductor presence and sizing, (reg 132.16) what tool, if any, would you recommend? Such as a cable gauge or caliper etc.
What do you guys use, apart from your eyes and experience?
I' d appreciate you suggestions.
Thanks in advance.
Why are you asking on there behalf?
If they or yourself dont know how to do it get a competant electrician in who can.
try and get some known sizes of earth cable then offer them up to the existing earth cable for a good indication.
electrical wholesalers should have some off cuts they can give you.
Not really the response I was looking for! I thought this forum was to help each other? (see forum's statement below)
(Please be reminded that if your reply can't help the original poster, it may be seen as pointless and taking the thread off topic. Please make sure what you are about to post is in-keeping with the forum rules, specifically the "be nice" rule. Just be nice and helpful (even to new members) or don't reply at all please. Also note that we urge all members, regular or new, to report any posts that are off-topic, pointless or offensive)
Just to re-clarify:
I have a team of cooker installers who need to confirm earth & bonding sizes, I have the skills to do so, but I am in an office, I cannot expect a cooker installer to know how to, hence the question.
Just to re-clarify:
well if YOU know how to do it why don't YOU tell them?
Hi All,
Thanks in advance.
Measure the end to end resistance and the length, then look up the csa in the appropriate cable resistance table. :-)
Just to re-clarify:
well explain to them how to do it then.
Got to be a wind up, Cooker installers wtf is that, are the "Cooker installers" going to check the main water bond as well? the OP ought to furnish his "Cooker installers" with a MFT to check, oh sorry you need to go on a course to do that, "Cooker installers" my bottom.
Heres the answer for you then.
Firstly you need to check that the pipes are exteanepus conductive parts ( the test for this is explained in GN8). Now as this requires you to disconnect any bonding conductors you need to safely isolate the whole supply to the installation, but you know how to do thos already dont you?
If it requires bonding
Use the correct meter (according to GN3) to check the end to end resistance of the cable, now this has to be done with cable disconnected at both ends and with the whole supply still isolated from previous test, the result must then comply with the value within GN8
The cable must then be correctly sized for the earthing system in place and size of the incoming neutral.
A cooker installer, is an installer who can safely install electric, gas and dual fuel cooking appliances.
All of them have a MFT (Fluke 1652) and perform polarity, EFLI pre and post installations, but they are now expected to confirm reg 132.16.
I don't get the negative posts here, I just was looking for some pointers to make their lives a bit easier.
Why all the negatives vibes?
yeah exteanepus, that'll really throw him lol
Because you should be capable of teaching them how to do this if your claim earlier is correct.
I hope they carry out all the dead tests too and in the correct order, and understand the results also.
if these cooker installers are expected to check earthing and bonding, then they should have been trained how. you could help by telling them where the connections are if they are not obvious.
I could easily quote from a GN etc, but those publications are intended for a competent person.
Perhaps I should teach them all the adiabatic calculation?
But thats what they need to learn and understand, theres more to electrics than just this cable will do attitude.
This section of your earlier post is really confusing me. Firstly you say these cooker installers need to confirm earthing and bonding sizes. Then you go on to state that you would not expect a cooker installer to know how to.
So so if you don't expect them to know how to verify earthing and bonding then why are you expecting them to do so?
Perhaps you should yes. If they are not competent to do their job, then why are they carrying out testing of circuits and installation of appliances ?
City and Guilds 2359 Level 2 qualification in Installing Consumer Electrical Equipment, full CCN1 and CKR1 Gas safe quals and internal training covering off electrical testing.
The guys are competent in their field, but are not electricians.
that beats my "width underwater" swimming certificate.
What do they learn on this course?
Who has decided they need to ensure bonding is the correct size and in place?
London
Earth and bonding cable checks-any tools available?
Tof99,
Geordie Spark,
