P
Piratepete
Hi Guys
I don't normally do 3 phase so just need to confirm this.
Local church has a 100 Amp TNCS 3 phase supply. All electric heating spread across phases.
I have to put a supply to a new extension also with electric heating, water heaters, hand driers etc. I'm proposing running the heating off one phase and the rest off another.
I'm proposing a 63 Amp 3ph Switch fuse at the meter end supplying 2 CUs in the extension via a 22metre long surface mounted 4 core 10mm SWA XPLE cable using one core as earth (I prefer this to using SWA as earth)
Is this OK? In particular cable and earth size.?
Pete
Pete
