Search the forum,
Discuss EDF refusing to fit a meter until signed off?! in the UK Electrical Forum area at ElectriciansForums.net
Rockingit
Mentor
Supporter
Have a builder client desperate to get some temp boards into some new builds just about at the electrical first fix stage, DNO have put the supplies in but Eon (subbed to an EDF fitter) have refused to fit meters until the whole lot are finished which is clearly ridiculous. Anybody else ever had this problem?
Since when did suppliers care what is going on after the meter? The installation has nothing to do with them sounds like you have a jobs worth, or someone who doesn't know what they are talking about
Just pay a bit extra and get them to install a 100a DP isolator after the meter so they are devorced from the installation.
I'm going to need to fit an 80A fuse anyway as all the tails are going to be via SWA. Dull.
how can you sign off the job before they fit the meter how can you do your testing without power ? they are not responsible for anything after the meter so they can not refuse if they do ask them if they are taking responsibility for it and then they have to do the testing and you wash your hands of it. but to be honest i have never heard of anyone refusing to fit the meter until the job is done.
I have had the situation quite often in the past and getting hold of a helpful person on the other end of the phone is invaluble.
We have had to provide dead test resuts at times to get a connection.
Why don't you fit and connect your switched fused isolator and supply a dead test EIC, IMO they cannot refuse then.............
We get a seperate supply and meter fitted just for site power
But that's just it - this is for temporary boards. So as long as the board itself has a cert, I can't possibly see what difference it makes. Now....if someone said it was a building site and therefore can't be TNCS, fine - but that's not what's happened!
- - - Updated - - -
Reply to EDF refusing to fit a meter until signed off?! in the UK Electrical Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
Hi All On the 2nd November an EON contractor attempted to fit an electricity smart meter at my address. He was unable to do so because the...
6K
Hi all I have a customer who wants a smart meter .. they are with edf .. The existing meters ...1 day rate , 1 off peak ..plus mechanical time...
5K
