Search the forum,
Discuss Electric Shock off a Light Switch in the UK Electrical Forum area at ElectriciansForums.net
If cause is static electricity then you wouldn't necessarily need an earthed surface to be touched to allow discharge. In fact there would be a bigger discharge if there was a small insulative air gap . Its possible if the cpc was a (few) mm away from a fascia screw tip then a large build up of static eventually discharged across. I don't think you would necessarily see a visible burn Mark.
Some people are particularly susceptible to static build up just because of their physical chemistry. And I'm not saying they don't wash!
Reply to Electric Shock off a Light Switch in the UK Electrical Forum area at ElectriciansForums.net
