Discuss Emergency Light testing and repairs in the UK Electrical Forum area at ElectriciansForums.net
I have a couple of questions about testing and maintenance of emergency lights.
  1. I have been told that if the LED on an emergency light does not work it must be considered “Failed” and the fitting replaced, but when reading up, I cannot find any regulations or guidance to suggest this is correct. The documentation only talks about emergency lights working once power has been cut. Can anyone help?
  2. All lights work in maintained mode. Some lights need new batteries, but there are some lights that do not come on at all when the power is cut (LED indicates battery is charging).
    Is it best to try replacement batteries in these lights?
    Or, should I replace the emergency module as well as the battery?
  3. Any advice or experience would be welcomed.
Regards
Not too well up on current requirements but this is what I believe to be the case:
If the charge LED does not work then there is no way to confirm the light is charging, the easiest resolution is to replace the LED, not the fitting.
However I am not sure that it is essential to have the LED but charging should be able to be confirmed so that a faulty light can be replaced.
If the indicator light shows the batteries are charging and then the fitting does not illuminate on power failure it is likely it is just the batteries (or possibly just the battery connection). This is assuming that the lights are lit when the power is on.
1. The led actually shows voltage is present at the charging circuit, and is no idication that the battery is charging. If there is no led lite, there is a good chance the batteries have gone, and either taken the charging fuse or charging circuit.....So answer is investigate or replace.
2. Again investigation time, these days a new fitting is more cost effective.
3. Hope the above helped
Reply to Emergency Light testing and repairs in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
