Customer wants to take power from an existing garage (with board) to supply a greenhouse, to be fitted with ip rated switchgear.
The greenhouse is made of aluminium.
Since this is an extraneous conductive part am i right in thinking that the aluminium frame would require a 10mm bond at least? (tncs supply)
Garage is fed with a 4mm armour (3core)
Should i still take the supply from the garage but run in a seperate 10mm earth from the house MET?
What's being put in the greenhouse? Maybe an IP rated outlet just outside it would allow use of garden tools etc.
Glasgow
Extraneous Parts Earth sizing
Neon Vagabond,
Neon Vagabond,
