Discuss Fire rated clips - any suggestions? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you kicked his dog or summat Murdoch?
Excellent response and says it all, for those looking for cables for Twin and Earth have a look at SWA they have a number of different clips by different manufacturers that can be used.
The risk assessment would be that BS7671 specifically permits the installation method of "no fixings" for the cable type being installed, therefore this is acceptable.Having been around court cases and H & S prosecutions for many years explain how would you write a risk assessment that says this unknown type of plasterboard will be my only means of support for the cables I install?
It is certainly your choice to disagree with the regulations, especially as the specific permission is informative, and for you and others to follow alternative guidance that is in excess of the regulations.Richard Burns #70. I, as you would expect, would disagree completely
to me the regulations, past custom and practice all lead to fixing the cables correctly. I state this as my interpretation only and it is the guidance all of the electrical contractors I support are following.
We will leave it here but plasterboard is NOT a means of supporting cables.
Yea but its funny to use on muppetsSo @FLICK ...... you’ve been dishing out the dumb rating like confetti
But offering up no opinions of your own
Sad really .......
Sad really .......
It would take a lot better than that to annoy me weirdo.You ARE the muppet.
Troll alert. Flick do you have anything useful to say?
Not really but then again it's none of your beeswax.
That's rich from someone that's used it 84 times if it makes me dumb it must make you dumber.I doubt it.
Using the dumb button 8 times is dumb ... but the mods think it’s a good idea to keep it - I think it causes more problems
I doubt it.
I wasn't going to say anything but I'm sorry didn't you use the very same rating earlier today, and after you said we shouldn't have it.
But it can't work like that can it , surely you must be able to see that.Of course I used it .... on the person who used it 8 times in 1 thread , so very justified imho
You cannot complain constantly about the dumb rating and ask for it to be removed because in your words it causes problems and then go and use the very same rating on someone else, it doesn't matter that someone used it on you , if you truly believe it's wrong then you can't use it yourself when it suits.
Surely I'm not the only one that thinks this.
Reply to Fire rated clips - any suggestions? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
