If you are not Vat registered you can not add Vat to the customers bill! What you can do is charge the customer the price you paid for the materials. i.e. including Vat. In fact you can charge anything you like for materials. Then add on your labour fees.
If you want to charge Vat you can register. Problem is then any domestic work you do is 20% more expensive then a competitor that isn't Vat registered!!! If your Turnover above £77,000 you legally have to register for Vat!! You need to look into Vat to understand how it works.
No Vat number, no additional Vat can be charged to customer. Remember HMRC can be a very powerful enemy! Just ask Glasgow FC! Don't mess with them.
Too cheap - use SWA- dont show VAT as seperate item ( they will want to claim it back ) I would photo cell and timer ( photo cell on - timer off )
I suppose that would depend on what you're being assessed for. If it's on commercial or purely domestic.
I would agree, I don't think you have given yourself enough time, also screw, raw plug, sleeving etc. also include vat unless your vat registered, maybe just give parts figure as a total unless they have requested a breakdown, prices may change if you have to use another wholesaler or something like that (unlikely but a possibility). Swa would be quicker to install but you need to include external glands with price too.
Chris
Glands are only about £2.50...would be a better job imo...no worry about water ingress either...
Sent from my Xperia S using next doors WIFI
I would use SY cable as mechanical protection built in and stuffing glands into wp wilka boxes. which is then locally terminated into the light fitting. Or dependent on fitting wire SY direct into fitting.
IIRC the steel braid isnt armour it's screening and so not mechanical protection...
i would use SWA. make sure you use the CW glands. and 3 hours is tight IMO, more like 5 hours, then what are you going to earn in the rest of the day? as for the VAT, if you are not VAT registered, quote your materials inc. VAT, then add labour without VAT.
Fellas
Thanks very much for all of the replies. I have now revised my plan and quotation as follows:
Install 24 hour timer on existing office lighting circuit adjacent to switches. Run fifteen meters of 1.5mm SWA from timer to IP65 rated junction box mounted on the roof next to signage. Install four floodlight extension arms (would like these to be about 30cm but struggling to find anything) at suitable intervals above signage. Replace the supplied floodlight (four in number) cabling with suitable cable and attach to IP65 rated junction box through stuffing glands. Mount floodlights on extension arms.
My new quote is:
Materials
ZXL floodlight (supplied)
New PVC floodlight flex
Floodlight extension arm
5 Pole Wago’s
Stuffing glands
1.5mm SWA (Steel Wire Armour cable)
SWA gland pack
SWA cleats
General purpose 24 hour Timer
Sundries (screws, Wall plugs, etc)
Labour
4 hours
Quantity
20 meters
15 meters
Cost
£00.00
£22.97
£02.97
£06.30
£01.73
£24.30
£03.33
£00.52
£21.20
£02.50
£100.00
Total
£185.82
I need to add on the cost of the extension arms when I find something suitable. Any suggestions would be welcome.
Cheers
'Example is the school of mankind, they will learn at no other'.
Still think you are giving too much information to the client and you should charge at least £200 for that if not more.
Hi Murdoch
Thanks again for your feedback. I am just starting out on my own and am not really sure where to pitch my pricing. I have plumped for £22.50 an hour initially but will adjust this depending upon demand for my services.
Are you advising £200 with the cost of the parts, I am not far away at £185.
Cheers
'Example is the school of mankind, they will learn at no other'!
Just a quick one. Can't you give a breakdown of the work to be done but an overall price for materials not an itemised price? I
