Discuss Gold twin plug sockets with USB! in the UK Electrical Forum area at ElectriciansForums.net
I thought it was just me.and that right hand screw wants a little tweak. it's not quite vertical.
No they have to be the same.It could be that the left hand screw is over tightened .. very slightly.
it's a socket that a plug goes into, as opposed to an eye socket, that an eye goes into. sssssimpless. DOH.What's a plug socket?
So, not the same as a socket plug then?it's a socket that a plug goes into, as opposed to an eye socket, that an eye goes into. sssssimpless. DOH.
I do prefer the 45 degree but both pointing the same way.If they were both at 45 degrees from vertical, would the tops of the slots have to slant the same way or opposite ways ?
Never had a problem with them just skip IR on line/neutral.they are useful the only problem is most dont let you do ir even though they state in instructions they will pass ir tests.
12 and 6 or 3 and 9?
Reply to Gold twin plug sockets with USB! in the UK Electrical Forum area at ElectriciansForums.net
