C
cllelectrical
I need to find a main switch to fit an MCCB board. There is no writing or stickers on the board.
All I know it that the breakers in it are Hager H125Ds
Can anyone shine any light on this?
I will get a photo tomorrow.
Its not the one on that link though, its bigger than that. Its an MCCB board, so main switch will be at least 125Amps I think.
Thanks for your help.
It'll be along the lines of one of these,
...maybe with adjustable 100A to 125A...
When a current rating forms part of an MCCB model/type number, it will be what is known as a ''Frame'' size''!!
Thank you. It is the main switch I need though, as there are just bars bolted in there at the moment.
Then you'll need to assess what the maximum load is on that MCCB panel and provide a suitable sized Main MCCB breaker.... That or a suitably sized isolator switch, (depending on the upstream protection being provided)
Thank you. I called Hager's technical helpline! Don't know why I didn't think of that sooner!
In case anyone is interested, or searches for this in the future, the model numbers were:
Board - GN208P
250A Isolator - GN323S
Hager H125D MCCB - What board/ Main Switch???
cllelectrical,
cllelectrical,
