Search for tools and product advice,
Discuss halogen bulbs in kitchen ceiling keep going of then on again a while later in the Lighting Forum area at ElectriciansForums.net
PaulRea
I have 9 x halogen lights in kitchen ceiling 3 in each transformer wired into the main ring. the centre set come on then go off, then come back on again a while later, repeating this process. is it the bulbs or is the transformer on its way out ?
I would say transformer on the way out.... it’s overheating, cutting off, and then resetting when it cools down.
maybe think about this as an opera unity to have all the lamps changed to 230v GU10 LED ones? They should fit in the existing fitting, and will be less hot and save some electricity.
Sounds like the transformer is failing. As above, ideal time to swap for LED.
Reply to halogen bulbs in kitchen ceiling keep going of then on again a while later in the Lighting Forum area at ElectriciansForums.net
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hey all. New here and new to 3 phase. I had some electric experience on set in Los Angeles as a gaffer for a couple of years, but it was mainly...
