Guest viewing limit reached
L
lost
recently bought a 200amp welder and i need to be able to run it off normal mains socket. problem is it requires a 16 amp fuse i believe.
what can i do ?
thanks in advance
Call a professsional electrician and they will install it for you properly;)
Job done....any other questions:D
problem is that i need to keep it mobile. was actually hoping to be able to run it of my generator i have in my garage (not possible to have mains power there as half mile from my house)
Fine, then run it off your generator
your genny will need at least a BS4343 (BS EN 60309-2) single phase 16 socket outlet,
and be rated at probably at least 5Kva
OR get a sparks in and install socket as above on a dedicated radial, with probably a Type D 16A BS 60898 MCB protecting it
and you cant run it off a normal mains socket!!
thanks everyone
looks like only my little welder will be moving down the garage , my bigger one (16a) will have to be kept at home for my heavier work
thanks everyone
but i dont see that youve solved anything:confused:
unless of course youve got a 16A BS4343 socket outlet on type D 60898 at your house
i know mine didnt come with one.....:p
sorry ,i missed this one .was this guy trying to run 16a through a 13a socket ? for f**k sake!!!!!!
You can! just put a nail in the plug top.
on a serious note does anyone have any knowledge about welders tripping out stuff?
i know they will trip elcbs what about other types of breakers?
rum, generally welders need to go on a Type D because of the surge (I worked on the bloody things for 20 odd years - pain in the butt!)
Some may get away with a type C, but theres a big surge
Type B's are 3-5 times IN
type C's are 10-20 times IN (I think , or was it 5-10 times? aint got the ook in front of me)
D's are 20-50 times IN, (i think) so they can handle the surge
and ELCB's, jeez thats going back a bit - worked with the current ELCB and the old VOELCB's (the voltage operated ones)
we used to have mobile cabins run off gen sets protected by them:eek::eek:
Help with 16amp (i'm not an electrician)
Talk Electrician Forum
lost,
Shakey,
