• Please checkout this (ad-free) update post I've done on a spare blog. Feel free to bookmark it and check everynow and again for update if ads are pissing you off. Always feel free to ad-block them for now though if you want. I'll let you know when you can disable the ad blocker again, only if you want to see the ads. They should look nice and neat in the end.
Discuss How has 2022 been so far? How's the economy affecting you? Any tips? in the Electrical Forum area at ElectriciansForums.net
Dave OCD
Mentor
Oddly enough I'd been looking at PIV units a couple of days back. No real issues with damp or condensation, but like to keep it to a minimum and felt it was a good means of introducing airflow.
Think I've settled on the Nuaire Drimaster Eco Heat HC. Don't intend using the heater much, but it seems a sensible option to have in colder weather.
That's exactly the one we always use, excellent bit of kit - although some customers opt for the unit without the heater. In all honesty the relatively gentle air input wouldn't unduly lower the temperature within the house in my view, and you can wire these straight off the nearest suitable lighting circuit with no concerns. 'HC' is quite important as it means 'Hall Control' where the speed control is mounted on the diffuser under a clip on cover - the other type- 'Loft Control' are a bit cheaper but you have to get in the loft to access the controls - bit of a PITA. :)
[The ducting is a bit fiddly to connect due to its size but you get the hang of it after you've installed about 50]
nicebutdim
Need to measure the landing ceiling to see if it goes over the landing or stairs (hall control a little less useful in the latter instance). Loft access is easy enough, but local control seemed a useful addition - especially given the additional cost of wall switches.
I'd figured unheated would probably be fine, but figure it might be nice to have the option of keeping the chill of introduced air on very cold days. I don't mind spending on the right gear, but misery will prevent heater being used in all but the most extreme cold weather.
I had looked at the newish Vent Axia units, which are competitively priced, but prefer the idea of cable suspension - that and a general aversion to Vent Axia products.
LukeD
Thats one of the best
Reply to How has 2022 been so far? How's the economy affecting you? Any tips? in the Electrical Forum area at ElectriciansForums.net
  • Locked
Good evening! Majority of the work I've done over the past 10 year or so has been new build full rewires and rewires of existing premises and...
6K
is in your vehicle when it is parked up This makes interesting reading although the concept has been around for a while...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
New Posts (Please Reply)
