OP
Knobhead
Sorry but what I'm planning will take time
Discuss How to connect motor? in the Electricians' Talk | All Countries area at ElectriciansForums.net
Ideally... you should continue your original thread on this same topic to keep continuity.
If your brown wires are switched from L1 and your black wires from L2 then your diagram doesn't make sense, unless:
(A) you have the labelling of the motor terminals incorrect, or
(B) you have something else "within" the box that you depict as the 'isolator'.
It would perhaps make sense if you had U1, V1 and W1 on the left of the motor terminal block with W2, U2 and V2 on the right of the terminal block, assuming the six wires are identically paired through the isolator. Please check this.
I know you are making a great effort in having us understand your plight but you must understand we cannot see what you have.
What's happening in the isolator. Is there 3 phase into the top of the isolator?
Are you certain it's an isolator as opposed to some form pole-reversing switch?
The six wires to the load... are they paired-up in the bottom of the 'isolator'?
It could be a manual Y/D starter (manual change over) switch.
Have you opened up "the box"?
If it is what i think it is, then it probably does not comply with legislation now, & no I don't mean BS7671.
Without more info then there is no more I can suggest, sorry.
we might as well get a mini bus and go down and have a look
Reply to How to connect motor? in the Electricians' Talk | All Countries area at ElectriciansForums.net
