Discuss I am Pricing a Block of Flats in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Molly58
I have been asked to feed the Flats Consumer unit with 25mm 2 Core concentric cablefrom a Ryefield 18 way Board mounted at the Mains incomer. Does this comply with the 17th regs regarding mechanical protection. I must admit to using a 3 core swa in the past not concentric because of the termination problems at the consumer.
No it does not have sufficient mechanical protection, you will need to provide this where required.
Chris
Concentric submains should be in a trunking unless there is a riser cupboard (even then Id put trunking) as for the earth its part of the cable Spin check here for a bit more info on concentric cable Split concentric cable to BS7870 its a bit of a pain in a cu id imagine although wouldnt you be fitting a cable head in each flat for meter??
Reply to I am Pricing a Block of Flats in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi all, I hope you could share your experience and advice regarding supply 50 flats in 5 storey block of flats. We get 3 x 430A supply. What...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
