B
bolt the volt
whats the best timer that wont burn out in under a year (last one i used was a grasslin)
It is a bit of a double edged sword that one as a 3kw immersion runs very close to the limit of the 13A fuse for long periods. I always fit 20A DP switch myself..Thats why its always best to supply the timer with a sw/ fused spur , never direct , especially if its from a BS3036 board
If you want to make sure it wont happen switch it though a higher rated contactor.
