You're not??? Dammit that's the whole job screwed thenDepends on the KW ratings of these 3 appliances, and whether or not your intending to run 2 supplies or one based on those KW ratings. Unfortunately were not mind readers... lol!! :rolleyes2:
You're not??? Dammit that's the whole job screwed then![]()
Are the single ovens 3kw jobbies with three pin plug thingies on them???
There are some special oven and hob connectors around now, I fitted a cooker connection unit t'other day which had two separate outlets. My local supplier had it so it was probably CLICK.
