Discuss Induction hob with x 2 single ovens best wiring layout tips in the UK Electrical Forum area at ElectriciansForums.net
Depends on the KW ratings of these 3 appliances, and whether or not your intending to run 2 supplies or one based on those KW ratings. Unfortunately were not mind readers... lol!! :rolleyes2:
Are the single ovens 3kw jobbies with three pin plug thingies on them???
There are some special oven and hob connectors around now, I fitted a cooker connection unit t'other day which had two separate outlets. My local supplier had it so it was probably CLICK.
Thanks all. Not got the model details with kw etc yet. But can calc cable sizes etc no prob. Was just wanting to know the preferred layout. i.e seperate cable and oven switch for hob and two ovens on seperate fused connections or plug tops or both on dual ccu fused from oven switch
Reply to Induction hob with x 2 single ovens best wiring layout tips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
