doive1231
Hi,
I want to wire up a 12V DC timer (CN101A) to turn an appliance on and off. I have the found on the internet the following wiring diagram for the timer and not being too experienced I was wondering whether it will work if I make the connections as shown:
The timer does not show + or - so I am assuming the author has successfully identified the correct terminals and completed the circuit.
However, I have found a wiring diagram for the same timer for 240V use that I think is wired differently with two wires connected on the red (outside) switch connection.
Which diagram is correct?
Thanks for any help.
the 1st diagram is no good. you're only applying 12V to the lamp. more info on what you want to achieve would help.
As what Telectrix says, we need more info on what you are trying to do.
Your timer runs off 12V but can switch mains voltage (max 16A) The second diagram is incorrect for yout timer. It shows the timer wired to the mains via two fuses.
Hello,
I am wiring a 12V DC fridge from a 12V sealed lead acid battery and I want to add the timer because the fridge does not have a thermostat and would freeze my food if on constantly. Therefore the bulb will be replaced with a fridge in the diagram and I have the DC lead from the fridge. The battery will be charged via a solar panel and the fridge connected to the load output of the solar charge controller.
Thanks for your help. The fridge is a small one that you can buy in Argos etc.
The diagram shows two wires at the battery's negative terminal. Is it OK to attach two wires to the negative terminal or should they be joined before and have a single wire attached to the negative of the battery (or charge controller)?
I cant believe that a fridge from Argos needs to be controlled via a time clock to stop it freezing m8 ?
but to answer your question it don't matter where you connect the two negatives
Yes, the fridges are dual voltage and I use a mains timer for AC but I want to run it off grid, hence the DC timer.
The fridges are surprisingly powerful and will freeze milk and food very quickly.
I have a small fridge from Argos at work, for my milk for my brews. It doesn't freeze the milk.
Is this a plausible wiring diagram for a 12V DC timer?
doive1231,
rwyndavies,
