Discuss Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
I certainly would not be happy if that had come into my personal sphere of work. I'd be wanting to kick some arse in one direction or another.
Put as many measures in as you like but there is no accounting for other people's actions.
If you have 239Volts lingering around it can't be safe to work on, isolate all supplies, if it is an EM fitting and has been wired as some suggest, then it could be thats how it was wired in the first place, if what you say is true and it has been passed by NICEIC, then look no further.Remember dangerous occurrences have to be specified under RIDDOR
As an edit point which I missed on the above post, the OP says he thinks it should be reported to the HSE, he has to be praised for finding this anomaly, but again the HSE are hardly going to act as in this case there were no injuries, however if the OP was injured (God forbid) the first thing the HSE would ask is was safe isolation of all supplies carried out? if the answer was a no then it would be th OP's fault for not checking. They don't take mistakes in safety practices, take it from me,I know what its like to be on the wrong end of one of their investigations.
I don't understand what you mean by that. The measures put in place should have been installing to BS7671. This has clearly not been done and the installation left in a dangerous state with regard to maintenance.
Or are you saying ....... you can write as many rules in the regs as you like, but there's always some numpty working under a NICEIC banner waiting to put peoples lives at risk ?
It is a tricky one because you wouldn't expect the plug to be live, never assume anything I suppose.
The latter, the numpty who decided to power up a second bank of sockets using a flex with a plug on either end who wasn't a spark at all, the manager of the shop saving some money, you know "oh I can do that".
Both Andy.
Reply to Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
