Discuss Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
oooh...controversy!!
a) even though there should be there isn't always an accurate kitchen plan (sometimes just the pretty computer picture of the final product)
b) as the socket's/switches etc are in place and we're all (supposedly) singing from the same hymm sheet the cable runs/safe zones are pretty obvious when fitting a kitchen
c) as kitchen fitters know there are extendable brackets etc out there making it easy to work around a cable's safe zones when fitting cabinets.
if i knew how to add the little smilies i would add a nice happy smilie...
what he hell has that got to do with part p ?
So in he last 4 years you couldnt be bothered to spend just 2 days in college to learn the new regs that you need to get work ?
Pfft , thats your own fault.
He doesn't even have to do that, just pay for the exam and turn up. A whole £80 or so.
Double pfft, that's his own fault.
Now excuse me If I'm wrong but everyone moaning about kitchen fitters drilling their cables, you do measure out a kitchen with all the units so you KNOW where they unit fixing lines are? If you don't then it's kinda your fault but if not no worries
i totally agree with you lucas
you would need x-ray spex when drilling fixings for the kitchen units
what i used to do is mark the cable runs beneith, on the plaster with a marker pen
its so simple http://www.youtube.com/watch?v=DGROSJbCPV8
In my opinion all this safe zone business is asking for trouble,and was poorly thought out,obviously by someone with no experience.I mean all of us at some point have probably hung a cupboard and where are the fixings?at the edges,which is exactly where the safe zones are going to be when cupboards are fitted from one end of a wall to the other,right?Also why call it a safe zone?Its an area for cables and therefore carries a risk if you drill into it,hardly safe then is it?the term may be easily understood by us sparks but its other people who cause the problems usually and they probably don,t understand the the safe zone.Anything where there is a risk should be called a danger zone,whats next green flags for on on isolators!Back in my early days cables ran in logical lines horizontally or vertically from an accessory and if it ran somewhere unexpected such as up the bedroom wall to get into the loft for upstairs lights then you ran it through a box and fitted a blank plate,to give a visual indication that a cable was there,no problem back then.Sorry about the rant but I,ve been up half the night trying to sort a major mess out for a mate,retirement! its worse than working.
im a qualified electrician! the original socket is far too high above the worktops, just all needs re-jigging really
thanks guys!
also, i came across a lighting junction box under the floorboards.. all the terminals inside were being used by live/neturals and so someone has brought the earths OUTSIDE the jb and put them all into a chock block.. anyone ever seen this done? hmmmmmmmm
I think this was quite common at one time.
My parents house was built in 1956 and the original wiring, which was replaced only 18 months ago, was all like this on all circuits. In fact the ring mains only had twin cable and a separate, uninsulated, twisted steel earth, which was jointed outside junctions and so on.
My own house was rewired in 1979 by a qualified electrician of the day, who retired only about 8 years ago. All the lighting JB's are done like this too.
My own interpretation of the current regs is that this is unacceptable though, or maybe I'm being over-cautious?
This was common practice on lighting circuits, and I don't think there is a problem with it under any regulations I can think of. the earth wires should be sleeved of course. The reason was simple, if you have a four terminal junction box, and you need all four terminals for lighting circuits, terminate the earth elsewhere, and outside the box keeps the inside less cluttered. As long as good workmanship is used, whats the problem? That last statement is not an invitation!!
Phil
Reply to Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
