Search the forum,
Discuss Landlord Compliance - Query over documents in the The Welcome Forum area at ElectriciansForums.net
Hi,
The only instruction they had was to undertake works to bring the EIRC up to a satisfactory condition.
Fiona
I never looks earlier at the consumer unit schedule, it is not clear why they replaced it as the EICR shows no issues with it even the mention of the 16A mcb, as previously stated in #13 is not an issue from the way it is worded. It may be worth asking why it was replaced.
Just to add it also says that item 3 incorrect fuse wire has been used but could not see any BS numbers for fuse wire on the report (3036) ,Also agree that no code for the 16 amp MCB on lighting may be just a note) , So that just leaves the cross circuit, easy to fix at the time of inspection . As for The RCD readings I would Guess this is a dual split Load Consumer unit , I would say The EICR was not done correctly,
Agreed there is no indication of 3036 fuses on the schedule. The board on the EICR is almost certainly dual rcd, the board on the EIC appear to be rcbos although they are listed as 60898.
This to me is an example of people undertaking tasks they have inadequate competence for.
I think the mention of fuse wire may be an autofill from the cert software. Fusewire is used as an example of an incorrectly sized OCPD, not a specific issue.
The wording is exactly the same as it appears in the best practice guide for EICR.
my software also autofills a generic description as soon as I enter a code.
Reply to Landlord Compliance - Query over documents in the The Welcome Forum area at ElectriciansForums.net
Afternoon all, Just wondering what everyone's response to the following scenario is. Letting agents have asked us to carry out an EICR. There was...
5K
I've done a few EICRs for a landlord and the latest one of his I've given an unsatisfactory, I've advised changing the CU - existing one is old...
I hope someone on here can help me with this. My 25-year-old daughter is buying a house with her partner, they are just about to exchange and...
TLDR: is there a legal requirement to have a landlords supply to power an L2 alarm system? Mornin'. Non-electrician, under the cosh from an iffy...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
11K
