OP
Rauer
I would be going to b&q or screwyouonprice! To get a socket tester before traveling that far!!
Discuss Live sockets in the UK Electrical Forum area at ElectriciansForums.net
is there any class 1 stuff other than the sockets?..things that are `out of reach`..such as luminaires?.....`test` them?....how do you know the fault is on this final?...i assume it buggered off as soon as you isolated the supply to it?.....and it could of course be an appliance..(plugged in or connected)...not necessarily the toaster...Hi all,
I'm new here, so please go easy :yes:. Would appreciate some assistance though.
I've just been around to my mums and go a little buzzing type shock from the toaster. I only had my electrical testing screwdriver with me as i'm miles away from home. The screws are indeed live for this socket as well as for a neighbouring socket. Verified that it is a ring from the DU, and have killed the circuit.
I've checked the earth connections to the sockets and they are fine. Any ideas on how i can test and fix this up in quick time with no equipment. I know that really should have been carrying my Kewteck multifunction :6:.
I use mine for poking holes in plasterboard & stirring my tea. :smug:
With all this health and safety fuss I am surprised you still can buy them.Neon screwdrivers are the devils work and should be banned.
I take it there is no rcd, check they live conductors insulation isn't damaged check the ze, could be too high for the fuse/mcb to trip
It would be better to get her off the bread completely. To much bread ain't good for you. Buy her a nice healthy breakfast cereal like muesli or bran flakes, to get the bowels moving. Then the risk of electric shock will be gone as nobody will be using the toaster?By your mum a new toaster, job done. Better to be safe than sorry.
Failing that, continue with the cooked bread diet and get hold of a tester to see what's going on. Find and fix the fault and sit back with toast and marmite, Mmmmmm
Reply to Live sockets in the UK Electrical Forum area at ElectriciansForums.net
