Discuss Live sockets in the UK Electrical Forum area at ElectriciansForums.net
For the cost of your trip you could have hired a tester and have the job done...
Even without the correct tools you could have done some basic safe isolation and had a visual check of all connections on the circuit to check for damaged insulation etc.
Hi all,
I'm new here, so please go easy :yes:. Would appreciate some assistance though.
I've just been around to my mums and go a little buzzing type shock from the toaster. I only had my electrical testing screwdriver with me as i'm miles away from home. The screws are indeed live for this socket as well as for a neighbouring socket. Verified that it is a ring from the DU, and have killed the circuit.
I've checked the earth connections to the sockets and they are fine. Any ideas on how i can test and fix this up in quick time with no equipment. I know that really should have been carrying my Kewteck multifunction :6:.
is there any class 1 stuff other than the sockets?..things that are `out of reach`..such as luminaires?.....`test` them?....how do you know the fault is on this final?...i assume it buggered off as soon as you isolated the supply to it?.....and it could of course be an appliance..(plugged in or connected)...not necessarily the toaster...
Neon screwdrivers are the devils work and should be banned.
I take it there is no rcd, check they live conductors insulation isn't damaged check the ze, could be too high for the fuse/mcb to trip
With all this health and safety fuss I am surprised you still can buy them.
By your mum a new toaster, job done. Better to be safe than sorry.
It would be better to get her off the bread completely. To much bread ain't good for you. Buy her a nice healthy breakfast cereal like muesli or bran flakes, to get the bowels moving. Then the risk of electric shock will be gone as nobody will be using the toaster?
Failing that, continue with the cooked bread diet and get hold of a tester to see what's going on. Find and fix the fault and sit back with toast and marmite, Mmmmmm :)
If you arrive in a situation where you have no test gear and a urgent situation arises,there is usually a basic voltage tester available, it will give you good indication of faults and earthing problems
Yes,its the long forgotten set of test lamps,(in a past life it could have been the Hallway pendant) its available in most homes who have that new fangled electric lighting
I would rather leave the fault where it is & risk the electric shock than eat Marmite !!!
Thanks for the replies. It turns out to be a fault with a separate appliance which was plugged in (washing machine). When unplugged, the fault in the sockets (ie live sockets) disappears. Going to have to open it up and check the earth is where it should be.
Reply to Live sockets in the UK Electrical Forum area at ElectriciansForums.net
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi Recently my son complained that he was getting shocks from his laptop when plugged into the mains in his room. I checked the socket and the...
