Install a contactor switch, one supply from the db to the switch, wire all the showers from that. That way only one shower can operate at once.
Like it or not that animal exists boydy, take the building regs exams and the regs exam and hey presto qualified domestic installer, register with the selected body of your choice and away you go if you are daft enough those with sense get in with a fully qualified sparkie and get experience before setting out on their own.
So this downstairs bathroom is pre existing and doesn't have a hot water supply?
Yes, and it does - but to fit a shower pump you have to have a dedicated supply direct from storage tank & cylinder - Salamander Pumps even say you need a 28mm supply, not 22mm.
I could just use the existing 22mm hot and cold supply, which I think is what you are suggesting, but the risk is the pump cutting out due to low pressure if someone turns on a tap, etc. Also never getting a decent flow, which defeats the object.
Great to see Trev back, a decent respectable electrician, as rare as rocking hores Sh*t on this forum of late lol
- - - Updated - - -
A made up name by the NICEIC, total balls.
- - - Updated - - -
its not just the NIC Mike...they all have a collective responsibility for this shambles...
ELECSA refer to their members (regardless of their quals and/or competancy) as elecsa approved contractors....i think napit have something similarly sinister...
like you NEED their approval or something....
My missus gives me a pat on the back when Im going to work in the mornings. Does that mean I can call myself approved :ciappa:.
Boydy
it matters little to me whether a guy has done a full apprenticeship or a electrical trainee course. if he's competent to work in his chosen field through practical and theoretical training, and works within the limits of his/her competence, then i have no problem with that. and i stress the word competence. tin hat on, runs for bunker.
