Currently reading:
Main fuse upgrade and associated issues
Discuss Main fuse upgrade and associated issues in the UK Electrical Forum area at ElectriciansForums.net
I'm due to qualify as a domestic installer soon, and my brother, who is fully qualified, will be doing most of this work.
I have a 60A main fuse.
I currently have a typical domestic installation, i.e. cooker, immersion etc, and one electric shower.
Due to distances between hot/cold supply and downstairs bathroom, I want to fit an electric shower there too.
I'm also planning a new en-suite and want an electric shower there as well
i.e. 3 electric showers in total.
I can upgrade to 80A main fuse for free. 100A would cost nearly a grand.
Question: can I run 3 electric showers with an 80A main supply?
So this downstairs bathroom is pre existing and doesn't have a hot water supply?
Yes, and it does - but to fit a shower pump you have to have a dedicated supply direct from storage tank & cylinder - Salamander Pumps even say you need a 28mm supply, not 22mm.
I could just use the existing 22mm hot and cold supply, which I think is what you are suggesting, but the risk is the pump cutting out due to low pressure if someone turns on a tap, etc. Also never getting a decent flow, which defeats the object.
Great to see Trev back, a decent respectable electrician, as rare as rocking hores Sh*t on this forum of late lol
- - - Updated - - -
Like it or not that animal exists boydy, take the building regs exams and the regs exam and hey presto qualified domestic installer, register with the selected body of your choice and away you go if you are daft enough those with sense get in with a fully qualified sparkie and get experience before setting out on their own.
A made up name by the NICEIC, total balls.
- - - Updated - - -
its not just the NIC Mike...they all have a collective responsibility for this shambles...
ELECSA refer to their members (regardless of their quals and/or competancy) as elecsa approved contractors....i think napit have something similarly sinister...
like you NEED their approval or something....
it matters little to me whether a guy has done a full apprenticeship or a electrical trainee course. if he's competent to work in his chosen field through practical and theoretical training, and works within the limits of his/her competence, then i have no problem with that. and i stress the word competence. tin hat on, runs for bunker.
As I've said before, some of the fully qualified time served 20+ year guys round here are the worst for dodgy, rushed, crxp jobs I see.
You can get shower priority units that are popular in Ireland but not GB that do the same as Kate's excellent idea.
2NO and 2NC contactors could also be used but cost will escalate.
Also remember that even though diversity is not permitted a 60A fuse will take 98A for about 2.5 hours before blowing, so the fuse will not blow with ten minute showers even if they are all on at once, however if you can just make sure only 2 are on at any one time then an 80A fuse should suffice (if you have 7.5kW showers).
Plumbing is the best option as said many times above.
Well said. ....Now pray tell me and every other time served electrician exactly HOW anyone can claim to be competent to work in a customers home after 17 to 20 days of classroom training??
You can't, ....because it's just NOT possible!! All that comes from those short days of training, are folk that are under trained, under qualified, under skilled, inexperienced wannabe's!! And it need to be STOPPED!!
and if we all shove on in the right direction it will be n all....
takes the collective i dare say though on this one...
I too am bemused as to why the OP is on here if his brother who's doing most of the work is fully qualified why haven't you just asked him direct as it been mentioned in a few posts surely he is your first port of call or are we to assume he couldn't answer your question so you said you would put it on here?
Something doesn't add up here...
If the brother tale is just a fob off then i would rather than jump in at the deep end start on smaller installs and work your way up gaining experience through the journey.. TBH id start off with a wendy house and work your way up to a 5 bedroom set-up.
As your just barely walking out of the college or training course this really should be all still strong in your head although this isn't really about the question you asked its just things don't add up.
True, but that was only the showers, add in all the other circuits in the house with diversity included and you'd probably be up to 140A or so, which would put it somewhere near the 18-20 minute mark for an 80A fuse, or well under 10 minutes for a 60A fuse (If I'm reading the right graph, having to search for it on google).
I suppose it probably would be something that could be got away with for quite a while, but sods law it'd be Christmas day with all the family home and the turkey in the oven that the fuse would pop.
eta - Not that I'm involved in this stuff really, so I might have got it wrong?
Reply to Main fuse upgrade and associated issues in the UK Electrical Forum area at ElectriciansForums.net
