Discuss Making a circuit live prior to final fix in the Australia area at ElectriciansForums.net
M
Mattrivett
Hi
I have been asked to make a circuit live before the work has been completed.
The situation is that the boiler has been moved into an extension. The extension is at the very early stages and i will be running the cable from the C/U (No ring to spur from yet) under a floor in the house and along the floor of the extension (Upper floor) down the wall and to the boiler. This will leave the cable exposed down to the boiler and all the way along the joists.
Should I run it all in conduit so it is at least protected?
Matt
Reply to Making a circuit live prior to final fix in the Australia area at ElectriciansForums.net
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
